Posted by Haas on January 31, 2014 at 14:34:19 from (50.142.111.41):
In Reply to: Farmall A fan hub posted by Farmall A Tractor on January 31, 2014 at 12:46:36:
Use the same oil you use in the engine. D7 has it right as to how to fill the hub. There is a stand pipe inside the hub that drains the oil to correct level when you turn the fill/drain hole to the bottom. I would not use grease. This hub is designed so that rotation causes the oil to circulate through the bearing. You won't get that if you use grease. Pretty good design as many still going after 70 years!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
