Re: Throttle linkage
Posted by Janicholson on January 31, 2014 at 15:53:02 from (74.60.94.18):
In Reply to: Re: Throttle linkage posted by sony224422 on January 31, 2014 at 15:20:32:
The springs are meant to cushion the hand lever a little. This allows the throttle hand lever to be pulled so that it guarantees the governor arm is pushed to its max position. The spring (which pushes on the little bracket compresses some to assure the governor is wide open.
Wear on the pivot points and linkages, can cause the rod to be too short.
If you remove the linkage from the pivot with springs, so the governor control arm on the back of the governor can be moved to its maximum (against internal spring pressure), and tie it there, you will be able to adjust the hand lever and the spring system for full throttle at the next to last notch. (the spring to ward the drivers seat (IIRC) will be somewhat compressed in that position) Jim
