Re: 806 hydaulic oil leak
Posted by The tractor vet on January 31, 2014 at 18:10:23 from (75.19.125.103):
In Reply to: 806 hydaulic oil leak posted by RustyR on January 31, 2014 at 15:15:17:
Your unlatching valve is the problem . Unhook the linkage on the ft. and unscrew the whole pipe thing . Now If the end cap comes off with out the pipe ya gots a small problem Clean every thing up and blue loctite it and let it set up for a day and try again . Once out you take the valve apart and do not loose the little latching balls while doing this . Remove the tiny little pin like valve out of the center and replace said valve with new. Yea i know can i replace the tiny little o/Ring , now i am not sayen ya can't but i have never had any luck doing so so i just replace the valve . Keep every thing clean use no rags to wipe stuff off , use clean diesel fuel Kero. parts cleaning solvent gas i do not care what just as along as it is clean and use compressed air to blow dry . Clean up the valve housing and surrounding areas replace the o/ring in the vav
valve body and lube everything up before assembly . Once everything is back together some trial and error to get the latching valve adjusted a pressure gauge would help with this . An I T manual would also be a plus .
