Re: M Carb Problems - Sounds Flooded
Posted by charlie M on February 01, 2014 at 04:21:32 from (173.85.161.240):
In Reply to: M Carb Problems - Sounds Flooded posted by blohr on February 01, 2014 at 02:53:14:
Could be the engine is flooded. When you had the plugs out if you let it sit for a while the pistons will dry out. I've used a propane torch to ignite the gas in cylinders before to get rid of it. It will shoot fire out plug hole if you do that so you have to be careful. Concerning gas from the carb, those tractors when cranked a bit but don't start will always leak gas from the carb.On you're spark plugs you may want run a hotter plug.You may also need to do tune up with points and condenser or at least file the points.
