Re: M Carb Problems - Sounds Flooded
Posted by CharlieNJ on February 01, 2014 at 04:42:26 from (76.117.68.151):
In Reply to: M Carb Problems - Sounds Flooded posted by blohr on February 01, 2014 at 02:53:14:
Well, you have fuel, so how is your spark and compression? As you had the plugs out, recheck to see if you put the wires back correctly(maybe why it backfires). Check your points and spark, is that spark a pretty blue? And is your starter spinning the engine fast enough?
