Re: Farmall a torque tube removal
Posted by davset on February 01, 2014 at 05:53:15 from (75.143.183.112):
In Reply to: Farmall a torque tube removal posted by Jmoody on February 01, 2014 at 05:31:10:
Yes, it is fairly easy.
Disconnect the clutch linkage at the pedal end of the torque tube.
Support the transmission.
Remove the four bolts holding the torque tube to the transmission, then pull the two apart. There are two alignment pins that might make it appear difficult to separate, but it should come apart fairly easily. The drive shaft is connected to the transmission input shaft so you will need to allow enough room to pull the entire torque tube clear of the end of the shaft.
