Re: M Carb Problems - Sounds Flooded
Posted by Janicholson on February 01, 2014 at 07:03:57 from (74.60.94.18):
In Reply to: M Carb Problems - Sounds Flooded posted by blohr on February 01, 2014 at 02:53:14:
I agree with the other posts. I will add that when plugs get flooded they become fouled they might even look OK, but they won't fire. To fix them, put them on a concrete block or metal surface and heat them on the business end with a (propane only) torch till they burn off the electrode fouling. 20 seconds of direct flame each will not destroy them.
Put them in the tractor while warm! (I use a rubber tube that fits the insulator and start them in the hole with that (too hot to touch!)
If you have spark, we know you have fuel, it will run. Always shut off the fuel at the tank as a matter of policy, when the tractor is not running. This prevents flooding and possible dangerous leaking on the floor if the needle valve leaks. The fuel in a gravity feed tractor is always trying to get into the carb, as though a fuel pump was left on! (it was!,we can't shut off gravity) Jim
