They are about 1.25" into the casting (IIRC) but the best method is to weld a nut to the existing material then let it cool and back it out. To hold the nut in place a piece o plumbers tape about 6 inches long duct taped to the casting on each end will hold the nut upside down. The heat of the arc weld disrupts the bolt threads rust and they are usually not radically rusty unless they have been broken for a long time, and exposed to the elements. Drilling up into them is Ok. feel on the drill as it goes through the bolt, and into the space above the end of the bolt is important as who knows what bolt was used in the hole over the years. Even if it is bottomed out in the partial threads, it is pretty easy to feel the difference when it goes through the bolt and into the cast iron. The shavings from cast iron are near powder, the bolt will be harder, and make curled swarf. The best easy outs are not spiral, they are a square taper and straight sided. These dont swell the thing being removed, they just turn on it after being pounded in a ways. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
