Re: what's wrong with my 706
Posted by Bill Lisbon on February 01, 2014 at 17:59:25 from (69.89.162.192):
In Reply to: what's wrong with my 706 posted by truckerlary on February 01, 2014 at 17:47:41:
I've seen this happen before. Try changing your Hydraulic filter. If the filter looks like it's full of waxy gope, change your transmission- hydraulic fluid. I would suggest using Hy-Tran plus. You can get it at your Case IH dealer. It cost more, but it is worth it.
