Re: Farmall 350U Ignition Problem
Posted by charlie M on February 02, 2014 at 03:47:42 from (173.85.161.240):
In Reply to: Farmall 350U Ignition Problem posted by JeffL on February 01, 2014 at 20:13:34:
Have you tried checking a plug for spark to know for sure that is what the problem is? I'd also suggest making sure the rotor is turning inside the cap in case something is sheared or stripped in the distributor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
