Re: What Keeps The Cranckshaft pulley on a '47 Farmall Cub
Posted by screwstick on February 02, 2014 at 11:33:24 from (71.219.193.128):
In Reply to: What Keeps The Cranckshaft pulley on a '47 Farmall Cub posted by KCTractors on February 01, 2014 at 18:56:17:
"When finished, do you put it back on with a big hammer?"
You can if you want to damage the main bearings...
To reinstall properly, the end of the crank is threaded with 1/2-20 threads. Install a good length threaded rod and line up the pulley with the keyway. Use a plate with a hole for the threaded rod and pull the pulley on with a nut. Use anti-sieze on the crank and the threaded rod, along with a couple grease covered washers behind the nut to act as a thrust bearing. Some people heat the pulley up before installation, but its not necessary.
