Re: Super A Rear Rim Size?
Posted by gene bender on February 02, 2014 at 15:20:17 from (207.177.56.213):
In Reply to: Super A Rear Rim Size? posted by oldtractorfun on February 02, 2014 at 12:53:31:
If it measures 11in outside to outside they would be 10in You can get rims for that tractor from 7in to 15 there are different suppliers of rims that will go on your tractor BUT the four places where they bolt to the center will be differeent in style but still work as the original loops are no longer available. So if you want original factory type you will need to find used. You can grind off the little square mounts on your old ones and get new blank ones and then attach them using rivets. It has been done.If you are going to stay with your 11.5 tires you want the 10in rims. If you wanted new 9.5s get 8in rims.Its up to you your tractor and you can do whatever you like.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
