Re: Farmall Regulars and F-20s
Posted by DeltaRed on February 02, 2014 at 16:19:55 from (67.40.59.83):
In Reply to: Farmall Regulars and F-20s posted by biggerred on February 02, 2014 at 15:44:43:
I believe IH started the casting 'codes' in 1923.At the the start of the regulars(F series).Plus,Regular did not have a sn plate.Its number was stamped on the front of the left frame rail right behind the radiator.F-20 Had sn plate mounted on the tool box under the gas tank.If that is missing,the sn is stamped on the left frame between the clutch houseing and transmission.Plus,Regular was 3 sp trans.F20 was 4sp.There many differences.Once you learn them,it will de easy to differentiate.Steering gears,air cleaner mounts,fuel tanks.......
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
