Posted by D Slater on February 03, 2014 at 09:33:13 from (184.14.172.108):
In Reply to: 450 ignition advance posted by Hugh McKinney on February 03, 2014 at 08:59:19:
Probably have 5 notches on the rear flange of the pulley. Turn engine in normal rotation a full turn and the last mark to the pointer is TDC. Looking from the front back the next mark clockwise from the TDC is what the LP should advance to at full throttle if checking with a light. That's 16 degrees BTDC. Engine stopped time is set at TDC. Other notches are 25, 30 and 40 degrees BTDC. They are not used for a LP engine.
