Re: 56 corn planter
Posted by fixerupper on February 03, 2014 at 19:21:23 from (100.42.83.15):
In Reply to: 56 corn planter posted by farmall4856 on February 03, 2014 at 18:09:08:
Oh boy, it's been a long time since I had the 58, which is about like a 56. I put many thousands of acres through it and it was a six row narrow.
What comes to mind is wear of bevel gears and the hex shafts. The hex center of the bevel gears wears and the teeth wear thin. I had a few hex shafts on the row units twist off at a cotter pin hole so check those shafts going back to the units for cracks at the holes the cotter pins go through at, if my memory serves me right, the bevel gears. I think there's a cotter and a few shims at the bevel gears. If the planter has been properly serviced those cotter pins and shims will be caked in grease. It's pretty hard to check the clutch, but the clutch mating surfaces should be square and not worn rounded. If worn rounded the clutch will separate and slip/chatter under load planting heavy populations like planting beans. Probably every moving part will a little loose and worn but those old girls can still plant pretty well when they're worn.
Need plates? I have over a hundred of them. Jim
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
