Re: 56 corn planter
Posted by duane966 on February 04, 2014 at 04:05:12 from (216.255.28.183):
In Reply to: 56 corn planter posted by farmall4856 on February 03, 2014 at 18:09:08:
we ran a 6 row 56 planter for 8 years. while it was an improvement over the jd 494a it still had some weak areas. the closing system didn't allow for good seed to soil contact. the markers are weak. have to have a lot of plates. the knockout wheel didn't always work well. I highly recommend skipping this planter and look for a jd 7000. much better planter and tons of parts are still available through the dealer or shoup. not sure of parts availability for this planter. we finally started getting great corn stands when I bought a jd 7200. a cheap planter can cost you a lot of money.
jmho
good luck!
Duane
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
