Re: 56 corn planter
Posted by mkirsch on February 04, 2014 at 10:29:08 from (65.199.189.6):
In Reply to: 56 corn planter posted by farmall4856 on February 04, 2014 at 07:12:14:
It can be done, but it is pretty tight when you get there.
You need the rectangular seed hoppers for the outer row units. The round hoppers will rub on the transport wheels at 30".
There are two holes in the arm that holds the row unit. You will want to put 3/8x3" bolts in each of these holes to block rocks from being kicked up into the outer seed hoppers, as I mentioned earlier. Check the bolts frequently. If one is bent, broken, or missing, replace it IMMEDIATELY, or you will loose a hopper full of seed.
