Re: Super MD Disk Brakes Banging
Posted by mkirsch on February 05, 2014 at 09:59:51 from (65.199.189.6):
In Reply to: Super MD Disk Brakes Banging posted by Dan MD on February 05, 2014 at 09:38:26:
The steel surfaces of the inner brake drum, both sides of the actuator, and the bull pinion carrier, are worn from 60 years of use and abuse.
What's happening is the actuator is going past its limit, making the bang you hear.
The fix is to take the brake drum to a machine shop and have them mill the edge down. I don't know the spec off the top of my head, but with the two brake disks and the actuator stacked in the drum, lay a straightedge across the edge of the drum and measure down so many thousandths.
O.E.M. Tractor Parts used to offer this service IIRC. They would send you a replacement drum, actuator, and new disks milled to spec, and you would mail back your old drum and actuator as a core for minimal downtime, or you could send yours in.
