Re: IH creeper gear
Posted by Janicholson on February 05, 2014 at 15:12:34 from (74.60.94.18):
In Reply to: IH creeper gear posted by lee thomas on February 05, 2014 at 12:08:49:
If you are looking to go slow for live plant transplanting or other non PTO work, the Hydro creeper is the answer. It uses hydraulic power from the pump, or an engine driven front pump, to drive the PTO shaft with a hydraulic motor. The Throwout bearing is taxed from blocking down the clutch pedal to allow the trans to work. A ball bearing Throwout bearing is used, not the graphite style.
I know of no gears that can be used in the trans. Jim
