Re: IH creeper gear
Posted by Tracy Brown on February 06, 2014 at 05:30:29 from (192.208.128.64):
In Reply to: IH creeper gear posted by lee thomas on February 05, 2014 at 12:08:49:
I am considering buying a machine to part out that may have what you want. It is an industrial machine designed as an asphalt paving machine built on a Farmall 140 from the factory. You can drive it around like any other tractor. But when you are paving, you put the tranny in neutral, put the PTO in gear, then there is a lever you move to set your creep speed. You can go at a walking pace or barely move. The creep is fully hydraulic. Although you may be able to plumb it in to run on the tractor hydraulic, this machine has a separate hyd tank and pump(s) for most of this machine's functions.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
