Re: trans seized on H
Posted by Jim Becker on February 06, 2014 at 09:48:37 from (173.71.58.166):
In Reply to: trans seized on H posted by Rat in nb on February 06, 2014 at 09:38:31:
Ever change the transmission oil? There is probably water in there that has frozen. If you start the engine with the clutch down then engage the clutch, it will either stall or you will break something.
Loosen the drain plug and ease it open a little bit to see what, if anything comes out. If you get some oil, I am probably wrong and you have a different problem. If you get water or nothing, I am probably right and you need to thaw it out and drain/flush/refill.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
