Re: trans seized on H
Posted by old on February 06, 2014 at 11:52:56 from (72.251.71.68):
In Reply to: trans seized on H posted by Rat in nb on February 06, 2014 at 09:38:31:
Very good chance it has the same problem my Ford 841 had. Your likely to have some water in the transmission which due to this nice hot weather where not having is a solid piece of ice so yep no good. My 841 did the exact same thing would not turn over unless the clutch was held down. What I did was opened the drain plug up just enough that I had a bit if water dripping out of it and set a heat lamp next to the transmission and let it sit for a day that way. If you have a couple magnetic heaters those work well. Then once unfrozen drain and fill with new oil
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
