Posted by mkirsch on February 06, 2014 at 13:31:26 from (65.199.189.6):
In Reply to: 1566 lift pump posted by Richard G. on February 06, 2014 at 09:03:11:
I'm going to stick my neck out here and say it's the priming pump, since the real experts are being coy about it.
Definitely not a lift pump. You don't need a lift pump if the fuel delivery is gravity fed. When the tank is lower than the injection pump, as in a pickup truck, you need a lift pump.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
