Posted by gene bender on February 06, 2014 at 13:55:07 from (207.177.56.213):
In Reply to: trans seized on H posted by Rat in nb on February 06, 2014 at 09:38:31:
Cold weather makes the tranny grease stiff and the shift lever has moved out of the rails. Remove the shifter lever by driving the pin out then you can see they arent lined up. Mite need to jack up one wheel so its not in a bind but you should be able to line the rails again. Shift slow in cold weather till you get the end of the shifter built up. This is common in cold weather
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
