Re: Farmall M fuel line
Posted by notjustair on February 06, 2014 at 18:27:59 from (174.238.67.250):
In Reply to: Farmall M fuel line posted by Keith wager on February 06, 2014 at 16:23:11:
An M uses a lot if fuel but not THAT much. If you have a good stream you should be fine as far as supply. Did you try pulling the choke a bit and see if it helped? If it helps then you have a fuel problem. Depending on the job I have had to adjust the main screw on mine as it fell short under heavy load. Did you try that?
When I start my M with the fuel shut off I can get across the barnyard before it dies. It isn't slurping it up faster than it will drain through your line unless there is something else up. Is there a vacuum? Is your cap venting properly?
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
