Re: 560 alternator switch help please
Posted by mkirsch on February 07, 2014 at 05:34:50 from (65.199.189.6):
In Reply to: 560 alternator switch help please posted by Tractordanp on February 06, 2014 at 17:14:28:
There are two wires running from the generator to the regulator, F (field) and A (armature).
The F wire is the heavier of the two. Connect it to the single post of the alternator.
On the regulator end, move that same wire from the GEN terminal of the regulator to the BAT terminal.
Tape off the end of the A wire at the alternator, or connect it the same way as the F wire, by moving to the BAT terminal on the regulator.
That's it! You're done!
