Re: electronic ign.on ih mag.
Posted by jasinpa on February 07, 2014 at 07:39:59 from (67.234.166.174):
In Reply to: electronic ign.on ih mag. posted by joenetx on February 06, 2014 at 18:13:15:
unless you got a pulling engine & need a distributor , in my opinion a mag works better for everyday use , i have tryed distributors on many of my tractors and have found a mag. starts easy, dont have point problems ,and no worn out bushing & shaft to deal with ,and no need for that battery, when it is dead just give it a half a turn & its running hooking a external coil will work in place of the internal one but now you need the battery, a differant kill switch & some added wires , the IH mags are so widely used parts are easily advalible & will be for years , more companys are now making replacement parts then ever & cost comparison there about the same as distributors , problem is most just dont understand how a mag works & how to repair them , if yours needs a coil there around $60 check out McDonald carb online , they got all youll ever need
