According to the parts diagram, the far right lever controls the left valve body under the steering column. This either controls the fast hitch or a rear hydraulic outlet.
The middle lever should control the far right valve body, which is for the outlet on the right side, under the gas tank.
The far left lever controls the middle valve body, which is for the outlet on the left side under the gas tank.
It is possible the previous owner cobbled the system together just to make it work somehow. You would have to pull the sheet metal off and look to see what's going on in there.
How are you comparing speed? If you are comparing a loader arm lift with a loader dump, the lift will be slower because the cylinders are larger.
You have to hook the same implement to each set of ports to make a valid comparison.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
