see if the missing is restricted to 1 or more particular cylinders. do so by pulling one plug wire off at a time while engine is running. if so the problem is either distributor cap, plug, wire, or valve most likely. process of elimination can be achieved by swaping plugs and wires back and forth. if the problem moves to a different cylinder than it is a bad plug or wire. (I have had new plugs and wires that were bad.) if problem dont move than it is likely a valve probelm. if the problem is not restricted to particular cylinders then it could be a coil, condenser, or points problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
