Re: Super A Missing - Looked at Everything I Could Think Of
Posted by old on February 07, 2014 at 15:39:04 from (209.86.226.11):
In Reply to: Super A Missing - Looked at Everything I Could Think Of posted by rtr on February 07, 2014 at 14:23:19:
Mag or distributor??? Are the new plug wires true wire wires or ones made for a car or truck?? If they are not true copper wire wires you need to replace them again.
Next what does your spark look like?? You need a good blue/white spark at all four plugs that jumps a 1/4 inch gap or more. Also make sure the point gap is correct at all 4 lobes on the distributor. Gap should be 0.020.
Next make sure you have a good steady flow of gas form the carb drain plug. Catch it to look for water/dirt etc.
Also are you sure you have the firing order right??
