Re: IH Utility 300 Transmission Case Leak - Need Help
Posted by D Slater on February 08, 2014 at 10:55:22 from (184.14.204.229):
In Reply to: Re: IH Utility 300 Transmission Case Leak - Need Help posted by aejlpw3 on February 08, 2014 at 10:28:30:
Its leaking where I guessed which is bad news. If you plug the holes the oil will cause the T/A clutch to fail. Three seals can leak transmission fluid into there. Just as well replace all if going to a lot of work to split the tractor. center housing has to come completely out to repair all three. Just a guess but think some places will charge 1000 to 2500 or more depending what other parts are found bad.
