Re: thermostates
Posted by Paul from MI on February 08, 2014 at 18:33:38 from (204.106.248.120):
In Reply to: thermostates posted by jerry 4 on February 08, 2014 at 17:41:43:
Older tractors, especially ones set up to burn kerosene or distillate, almost always had radiator shutters to manually regulate engine temperature. The shutter was a sort of manual thermostat and was critical to burning heavy fuels. It is also important to maintain correct engine temperature on gasoline, but not quite as much so. Cold engine temps allow unburned fuel to wash past piston rings and dilute engine oil. They also increase spark plug fouling because fuel isn't burned completely.
