Re: Super A Missing - Looked at Everything I Could Think Of
Posted by Janicholson on February 08, 2014 at 19:55:10 from (74.60.94.18):
In Reply to: Re: Super A Missing - Looked at Everything I Could Think Of posted by RTR on February 08, 2014 at 14:01:09:
Many tractors go years between valve adjustments (if adjusted correctly) Putting a timing light on each of the plug wires individually first, looking for wheel jumping forward and back (not the timing mark, when it is running at a steady medium speed can show you distributor bushing wear. If the wheel jumps back and forth 1/4" or so as the light stops the wheel, the bushing is probably not good enough to make good timing. Jim
