More 504 hydraulic questions
Posted by chris cummins on February 08, 2014 at 22:01:19 from (70.194.200.249):
third party image
1st thing, thank you all.I always appreciate your help,Thank You!
I installed my filter cover as suggested, and have drained the milk water fluid from two plugs in the belly and the plug under the rearend I also flushed all lines,valves and couplers,ANY MORE i should drain?pto housing?axle housings?
Which plug do i fill from?i found these two(see pics)
Also before i took i apart the 3 point lift would change positoins by itself.i found this fork broke upon inspection and welded it back, Do i need to adjust anything here after i get it runnig
Thank you!
