Re: Farmall 460 gas power
Posted by Tractordanp on February 09, 2014 at 03:35:17 from (50.153.128.174):
In Reply to: Re: Farmall 460 gas power posted by Al L. in Wisc. on February 08, 2014 at 06:27:34:
Well I adjusted as per what you posted main fuel screw was at
3 1/2 turns so it's out to 5 now seems better but I did find a
bigger power loss guy told me tires where not loaded and I
believed him to be correct being the bakes on tractor work
very well
Well any who I could not get valve stems to take air or check
pressure so I jacked tractor up to change valve stems and
guess what tires right full of calcium chloride
So I guess tractor is not to bad on power
I am very surprised how good the brakes work with loaded
tires I have half a mind to pull apart to see why and try to get
my other tractors to work as well but then again I don't wanna
mess it up lol
Thanks guy dan
