Posted by Janicholson on February 09, 2014 at 08:28:19 from (74.60.94.18):
In Reply to: Re: Thermostats posted by BruceS. on February 09, 2014 at 07:35:20:
The starting valves should be closed (diesel mode) after shutdown in either case. The reason being that the valves when open are hanging in the combustion chamber with no edge support, and no cooling touch to the seat. I believe that leaving them closed provides less heating of the starting valves in the first place. The head castings are complex. The saturation heating from real work/load is as uniform as it can be through the mass of the casting. I see no concrete reason to "cool" it by using gasoline combustion exposing more surface area to heat. (I ride diesel busses every day to work. They have diesel powered heaters that provide cabin heat for passengers because the busses are not worked hard enough to provide engine heat to the heater cores) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
