Re: Hard Starting Super C
Posted by Janicholson on February 09, 2014 at 13:01:17 from (74.60.94.18):
In Reply to: Hard Starting Super C posted by Duane WI on February 09, 2014 at 11:10:20:
Even with 12v it might be time to check the cables and grounds for loose/corroded. To see if it is ignition related, use a different 12 v battery negative to ground, and positive to ignition input (coil if 12v no ballast required, or ballast if so equipped. Don't turn on the key as the ign jumper battery is connected. Spin the starter and if it roars to life, maybe a lesser ohm ballast resistor is needed, or a ignition bypass added. It is easy to do. Jim
