Re: Hard Starting Super C
Posted by old on February 09, 2014 at 13:32:01 from (209.86.226.56):
In Reply to: Hard Starting Super C posted by Duane WI on February 09, 2014 at 11:10:20:
Could be spark or fuel problems but only you can find out.
Check your spark first. Make sure it is a good blue/white and will jump at least 1/4 inch gap at ALL 4 plug wires.
Next pull the carb drain plug and make sure you have a good steady flow of gas out of the carb for a few minutes. Catch the gas to look at it for water/dirt etc.
Plus in the winter and the cold it needs a bit more gas to start so if it has an adjustable main jet you might try opening it up a bit
