The parts you need wont come from another unit. You have bushings two bearings two seals gaskets and maybe a new key for the gear. To start with have you checked the drag link to see if it moves back and forth just mite be loose on the shaft. If it moves up and down the top bearing is shot. How tight are the tie rod ends and does the steering shaft move endways when you turn the shaft back and forth as the bearing on the end of the steering shaft mite be shot. You do need to remove the axle before you can take the sector apart as the bottom section cannot be removed until the axle is out and then the draglink needs to slide off as the bottom is removed. I have done several of them and with good parts and full of 90wt they steer like new again.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
