Re: Steering rebuild Farmall A
Posted by RTR on February 09, 2014 at 17:35:35 from (74.240.94.59):
In Reply to: Steering rebuild Farmall A posted by Keith Calhoun on February 09, 2014 at 09:59:11:
I'm sure the key way and the bearings can be gotten from Motion Industries pretty easily with a little part number research (or use numbers from old ones). The bushings can be made at a machine shop if you'll remove the upper and lower castings. The gaskets should be really easy to get.
If you wanted to convert it over, get a good used shaft on eBay or parts place, then the new rebuild kits are EASY to get (for about $65.00) and come with bushings, seals, bearings, and gaskets.
DO NOT use parts from an old unit if you are rebuilding....swapping the whole front end is a different story. Will be like new in the end.
