Re: Hard Starting Super C
Posted by whigg on February 10, 2014 at 16:26:43 from (50.133.138.25):
In Reply to: Re: Hard Starting Super C posted by Gmitch on February 10, 2014 at 08:28:32:
I agree with gmitch . make sure all of the intake bolts are tight and the bolts that hold the carb to the intake.If it starts good in warm weather the steel will tend to swell and all the gaskets are tight. In the cold the steel will tend to shrink and the gaskets can leak causing the engine to suck air instead of fuel.This may not be the problem but it is a good thing to check. Hope this helps.
