Re: Hydraulic O-Ring Leak
Posted by Janicholson on February 11, 2014 at 15:08:30 from (74.60.94.18):
In Reply to: Hydraulic O-Ring Leak posted by Jim Sedgewick on February 11, 2014 at 14:51:10:
Be careful to be sure it is the surface between the flange and casting that has the leak. Many have cracked at the tube to flange (crack in the tube) and some have had issues at the braze of the tube to the flange. THere are Teflon rings available from Motion Industries and Kaman https://ec.kamandirect.com/us/index.jsp
You will need the ID and section diameter. Jim
