Posted by Nebraska Kirk on February 11, 2014 at 16:13:03 from (207.91.4.159):
In Reply to: f - 20 crank removal posted by Loren in WI on February 11, 2014 at 15:43:26:
I have driven several out with a heavy hammer and a block of steel against the front of the crankshaft.
The tool I made for installing the flywheel that screws on rear end of the crankshaft can also be used for pulling the crankshaft. I just made a bar and a pair of legs to span the end and use a 5/8" threaded rod and large nut for pulling. There have been a couple that pulled hard and I had to crank down on the nut pretty hard and then hammer on the front end of the crank (use a block of steel against the crankshaft for protection) to get it to move, then crank down on the nut again.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
