Re: conformatic pistons
Posted by burnt-smta on February 11, 2014 at 17:19:20 from (184.63.137.70):
In Reply to: conformatic pistons posted by burnt-smta on February 10, 2014 at 18:44:54:
Any idea were I might find rings? this engine has not run in 20 some years and everything looks real good inside but the top inch or two of each cylinder has some light rust from condensation and several of the rings are stuck, I would like hone the sleeves and re-ring the pistons along with new rod/main bearings and put it back together.
