Re: Re: Re: M radiator drain plug
Posted by Bart on December 17, 2000 at 13:03:16 from (209.91.44.38):
In Reply to: Re: Re: M radiator drain plug posted by Barry Wilson on December 16, 2000 at 19:15:20:
Barry, There are two bolts coming out of the bottom of the radiator. They each have a spring and a nut on them. There should be access holes if it's a wide front end and open area on a narrow front end. The nuts come off and not the bolts. Use a lot of penetrating oil,and a ratchet with extension. Maybe a little heat. Mostly it takes patience and a few choice words. Good Luck.
Post A Followup
: Re: Re: Re: Re: M radiator drain plug
