I used a piece of oak and a big hammer to remove them on a Farmall A in 1975. My engine was stuck so several of the pistons came out with the sleeve. I used an acetylene torch to heat the old sleeve to free the piston. I installed a new sleeve kit after steam cleaning the block. The crankshaft only needed polishing and needed .002" undersize bearings. I bought them from the auto machine shop. You need to clean that block area where the old seals were installed. There's probably a lot of rust and crud in that area. I used a 1/4" drill motor and a wire brush to clean that area. Coat your new sleeves with dish detergent and clean that recessed area where the sleeves sit at the top of the block. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
