Posted by mkirsch on February 12, 2014 at 10:04:48 from (65.199.189.6):
In Reply to: FROZEN CHOKE CABLE posted by PRTZMAN55 on February 12, 2014 at 06:43:33:
The battery charger thing is along the same idea as using a welder to thaw water pipes.
You connect the ground clamp to one end of the pipe, and the electrode holder to the other end, and turn the welder on. The electricity flowing through the pipe will cause it to warm up and melt the ice.
The key is using the right power setting so you don't melt the pipe!
Same deal with the battery charger. Positive at one end of the cable, negative at the other end. You probably want to put the charger on its lowest setting, and slowly increase the setting until the cable starts to heat. Too much heat, and you ruin the cable.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
