Re: One more question on MD shutdown
Posted by mkirsch on February 12, 2014 at 10:11:29 from (65.199.189.6):
In Reply to: One more question on MD shutdown posted by BruceS. on February 11, 2014 at 14:39:04:
Just to be clear, when people say "shut off the fuel" in reference to a diesel, they mean by moving the "throttle lever" to a shutoff position, or by pulling a separate shutoff cable attached to the injection pump. Depends on the engine.
You NEVER shut them off by closing the petcock at the fuel tank!
I expect that will drain the fuel filters, injection pump, and injectors. Then you get the lovely job of bleeding it all out again for the next startup.
Getting a diesel running again after you've changed filters, or run it out of fuel, is NO FUN. Any time you disrupt the fuel flow from tank to injector pump for any reason, you cause yourself pain.
