Re: Farmall A steering box
Posted by RTR on February 12, 2014 at 12:17:54 from (216.226.179.180):
In Reply to: Farmall A steering box posted by Keith Calhoun on February 12, 2014 at 10:25:04:
Yes it should work fine, although i would not re-use the bushings, seals, bearings and gaskets. Even if it seemed tight when removed, I would go ahead and replace all those parts while you have it apart.....especially when the kit is only about $65. You'll have to have the bushing machined down a little bit to fit your shaft perfectly but that isn't a big deal. That is the way they make them. The only reason you should change out the internal parts like you are talking about is only becuase you'd not want to keep the square shaft setup. Otherwise they'll be fine as they don't typcially wear out.
This post was edited by RTR at 13:07:54 02/12/14.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
