cant find my M book but my H book shows 1019 RPM @ operating speed ( wide open) , H & M's are real close if not the same , adding a hyd pump to the pulley should work fine , had a massy 44-6 that had a home made bracket & pump added to drive on pulley shaft, extra oil tank mounted on frame & 2 valve remotes on it , still wasnt live but worked double aution ,it was an older syle gear pump using 30 oil not hyd. fluid
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
